Evaluate the refinement to the contact filtering panel
Good afternoon
please evaluate the improvement to the contacts filtering panel, to the additional field block http://joxi.ru/LmGWbyDug9kGZm, when filtering by a field with a drop-down list, you need to be able to select several values with a multi-list
Fits. But please re-evaluate the checkbox to exclude the value http://joxi.ru/p27Y0R7sngqLZr, that is, we display all options except for the selected ones
06.08.2021, 18:56
with this setting - 2 hours, if only to implement the above setting (show the drop-down list as a multi-list), or for all filter options - 3 hours
Which implementation do you need?
09.08.2021, 11:11
did not understand, give an example for what other filters? Meant for any field type?
09.08.2021, 13:49
Yes
09.08.2021, 14:44
1 hour
we run only this part 1 hour (selection by multi-list when the field type is drop-list), on account of the paid hours of the project
09.08.2021, 15:32
Tell me, have you started the revision?
10.08.2021, 16:57
Yes, the revision is already done
Added setting "Allow to select multiple values for a field with a drop-down list type"
10.08.2021, 17:40
