address is not visible from the contact card
When a contact card update request is sent, the connection to the server is disconnected and the request is not executed. Check server settings
07.06.2021, 17:45
to clarify, be kind, what do you need to correct yourself?
07.06.2021, 18:14
I won’t tell you exactly what to check, you need to look at why the server is terminating the connection
08.06.2021, 09:31
OneBox Corp - Інтегратор
The card is not saved at all, the error flies that the request is too large https://take.ms/XUZEI can raise what limits?
08.06.2021, 10:48
dyakuyu, virisheno:
here /etc/httpd/conf/httpd.conf
adding LimitRequestBody 33554432
*but the main reason is a lot of automation when saving a contact card.
08.06.2021, 11:52
