Automation when creating a contact card works when saving a contact card
Hello.
Faced the following bug: for some reason, automating actions when CREATING a contact card works like automating actions when SAVE in a contact card.
Here is the video: https://youtu.be/QFLJZ2bZo74
There is a test contact card. It has a "Simple contact" field (contact field, type String). In automation, when creating a contact card, there is the "Change contact field" action, which assigns the value 1 to the "Simple contact" field. When CREATING the card, everything works - the field got the value 1. We try to change the data in the field, but nothing comes out - when SAVING the already created card, the value of the field "Simple contact" becomes equal to 1 again.
We disable the action described above when creating a contact card. Now the field can be edited and the data in it is not replaced by 1. We turn on the automatic action - again, when saving, it returns 1.
Please correct the contact automation functionality in the action plan when
30.03.2021, 15:20
Good afternoon, because you are still on the contact creation page. If you go to the contact card for the second time, nothing like this will happen
30.03.2021, 16:00
Thanks a lot!
Recently updated and now due to "saving without updating" the page is not even clear where we are. Can I somehow disable this feature and return the old page update when saving / changing fields? When the page in the browser, in fact, reloaded.
30.03.2021, 16:17
In the contact card, it seems like they should be located.
Unfortunately you can't turn it off.
30.03.2021, 17:45
