Good afternoon. When setting access rights for the Role, the My Events block can be opened https://prnt.sc/10a65fj without including anything inside, that is, inside all settings are turned off. With this configuration, all employees of this role have access only to their own events.
But if we set up personal rights when we turn on the https://prnt.sc/10a68ab block, it automatically turns on everything, so the employee sees not only his own events, but everyone. If we do not turn it on, he does not even see his own. If you do not include the general block https://prnt.sc/10a6ke0, while opening this employee personally https://prnt.sc/10a6hmy inside, you still cannot enter My events https://prnt.sc/10a6i9e. I check on an employee https://crm.hlr.ua/admin/shop/users/permissions/68382/#done
Tell me, how to open access only to your events in personal rights?
Good afternoon. When setting access rights for the Role, the My Events block can be opened https://prnt.sc/10a65fj without including anything inside, that is, inside all settings are turned off. With this configuration, all employees of this role have access only to their own events. But if we set up personal rights when we turn on the https://prnt.sc/10a68ab block, it automatically turns on everything, so the employee sees not only his own events, but everyone. If we do not turn it on, he does not even see his own. If you do not include the general block https://prnt.sc/10a6ke0, while opening this employee personally https://prnt.sc/10a6hmy inside, you still cannot enter My events https://prnt.sc/10a6i9e. I check on an employee https://crm.hlr.ua/admin/shop/users/permissions/68382/#done Tell me, how to open access only to your events in personal rights?
Shatokhina Irina wrote: Good afternoon. When setting access rights for the Role, the My Events block can be opened https://prnt.sc/10a65fj without including anything inside, that is, inside all settings are turned off. With this configuration, all employees of this role have access only to their own events. But if we set up personal rights when we turn on the https://prnt.sc/10a68ab block, it automatically turns on everything, so the employee sees not only his own events, but everyone. If we do not turn it on, he does not even see his own. If you do not include the general block https://prnt.sc/10a6ke0, while opening this employee personally https://prnt.sc/10a6hmy inside, you still cannot enter My events https://prnt.sc/10a6i9e. I check on an employee https://crm.hlr.ua/admin/shop/users/permissions/68382/#done Tell me, how to open access only to your events in personal rights?
set access only for your employee and that's it
Ustimenko Igor
So the rights are set https://prnt.sc/10ag721, https://prnt.sc/10ag2vg , but there is no access to the layout of my events https://prnt.sc/10ag4wb
Ustimenko Igor OneBox CTO wrote: Do you have access to events?
Yes, if you follow the link to a specific event, then there is access. And also in the process the letter is available for viewing. There is no access only to the My events page (despite the fact that the My events menu is open in the rights)
Ustimenko Igor
