Sort by contacts
Write, be kind, according to which principle contacts are sorted after a specific request
For example, just to open contacts - sort by #
And if you ask for a specific contact, sorting is sorted https://prnt.sc/yycx8c
So it appears on its own and at the request of the client (so you may not be on the drop-down list, as there are a lot of contacts)
It is necessary to sort by the name of the contact
Hello, sorting is by relevance. What is the "contact name" for you - his first name, last name, company name or patronymic?
11.02.2021, 16:56
here the client is asked like this:
sorted first by company name
There is no company - then by name, and then by name
12.02.2021, 12:29
2h as a setting in the system.
Specify exactly in what order to sort the companies (from A to Z or from Z to A) and Last Name with First Name, respectively.
12.02.2021, 14:39
accepted. I am contacting the client.
12.02.2021, 16:44
