I made a contact. There is no yoga in the list of contacts. With a joke in contacts - do not know. The group "Spivrobitniki" has no yoga. I would like to tick off yoga as a spivrobitnik, adding yoga to the Spivrobitnik group and in the settings, giving equal access to Spivrobitnik.
Through the global search - Yogo to know. The account itself is functional, it can be authorized and can access the admin panel.
Didn't realize why it's not in the list of contacts and not in the Spivrobitniki group?
I made a contact. There is no yoga in the list of contacts. With a joke in contacts - do not know. The group "Spivrobitniki" has no yoga. I would like to tick off yoga as a spivrobitnik, adding yoga to the Spivrobitnik group and in the settings, giving equal access to Spivrobitnik. Through the global search - Yogo to know. The account itself is functional, it can be authorized and can access the admin panel. Didn't realize why it's not in the list of contacts and not in the Spivrobitniki group?
Oleksandr, many times published screenshots with special tributes from the Koristuvachs, like confidential tributes. Is it ok? See them, be kind. Let me rephrase the food: I go into contact and choose a group of spivrobitniks - there is nothing there.
Shedko Alexander
I don't see the problem. Having tried to know your method, it turned out. Ale, just open a group of spivrobitniks without filters, there is no account there. Tell me, can I send a screenshot to someone? I do not want to publish special data of practitioners.
Loud Vladimir wrote: I don't see the problem. Having tried to know your method, it turned out. Ale, just open a group of spivrobitniks without filters, there is no account there. Tell me, can I send a screenshot to someone? I do not want to publish special data of practitioners.
Good afternoon, Volodymyr.
Similar to Bug displaying contacts.
As well as filtering by Spivrobitnik, then it displays 36 contacts and Store Lviv in addition, as well as displays contacts by tile or by list
https://i.imgur.com/Y1U4Q2O.png
http://i.imgur.com/qLAZtYw.png
http://i.imgur.com/wREocPp.png
and how to display a contact
and if you look at the contacts with the table, then it looks like 27 and the filter says 27, although їх 36 and under the table it says їх 36 https://i.imgur.com/ThEjOTp.png
Alexander Shedko wrote: Good afternoon, Volodymyr. Similar to Bug in the display of contacts. As it filters for Spivrobitniks, it displays 36 contacts in the Lviv store, in addition, it displays contacts with a tile or a listhttps://i.imgur.com/Y1U4Q2O.pnghttp://i. imgur.com/qLAZtYw.pnghttp://i.imgur.com/wREocPp.png How to view contact
Good day, Oleksandr! Well, it's amazing. Really looks like a bug. Tell me, can you fix it?
Alexander Shedko wrote: Loudly Vladimir wrote / a: can you fix it? You can fix the retailers.
Is it possible to ask the retailers to fix the bug?
Vladimir, try to create a new password for this contact https://prnt.sc/u537nc, save the changes, check if it appears in the list of employees and please give feedback. Thank you.
Bomok Vladimir wrote: Vladimir, try to create a new password for this contact https://prnt.sc/u537nc, save the changes, check if it appears in the list of employees and please give feedback. Thank you.
Vladimir, hello, just set a password, it helped. Thank you!
