https://onebox.mim.kiev.ua/admin/shop/users/19766/#done - the contact is in 3 groups
One of which is Employees - https://onebox.mim.kiev.ua/admin/shop/usergroups/9/interface/
The interface takes into account only for this group. It is also necessary to take into account blocks from other groups - https://onebox.mim.kiev.ua/admin/shop/usergroups/20/, where their blocks are displayed - https://prnt.sc/vldkjj
Previously, I remember the group interface was combined according to Universal blocks if there were different blocks in 2 contact groups.
How now to correctly configure or solve programmatically so that the interface is compatible with 2 or more groups if it is different?
Merging interface of contacts from different groups was not 100% As an option, you can try to play with setting the visibility of the fields / UB block Or if the contact has a group for which an interface that is completely suitable for you is configured, then you can try to set the sorting for this group higher than the rest and then it will be used to display
Maria Employee wrote: As an option, you can try to play with setting the visibility of the fields / UB block
In fact, I already did this, but here the moment is to make it more convenient
Maria Employee wrote: Or if the contact has a group for which an interface that is completely suitable for you is configured, then you can try to set the sorting for this group higher than the rest and then it will be used to display
Maria
Maria
https://prnt.sc/vlg0j5 - it doesn't work if you say sorting should affect
Timofeev Artem Olegovich
if here https://onebox.mim.kiev.ua/admin/shop/usergroups/20/ I set sorting 999 - then the contact will have an interface according to this interface setting
