Evaluate the completion according to the Personal Account (order without goods)
1. You need to evaluate the opportunity when entering the "cart"
In order to be able to start creating an order without a product, it is not possible right now :(
It is necessary that all blocks are displayed as usual. How much would such a setup cost?
2. I need to add an option in the shopping cart, if I created an order without a product, so that I can add my own fictitious products.
That is, to have an empty product table, the example now looks like this (if you add a product to the cart and delete it)
How many hours is this?
3. In the table from point 2, you need to be able to display which fields (fields of process products). Accordingly, when creating an order, so that these data are transferred to this order for each product
4. Now when I added a product to the cart, it remains, it is important that this function remains when implementing points 2 and 3
How many hours is this?*
Why is all this,
integrator
integrator.com.ua
as an option - you can enter in the account /admin/shop/boxclient/menu/block/settings/ in the menu Add a request like this https://prnt.sc/vha9g6
and allow you to choose your business process in the request https://prntscr.com/vhabe6
then in the request https://prnt.sc/vhaqmc you will be able to simply write a comment, which will be written in the description of the Order and the goods do not mind.
And for the client in the office, give instructions.
pidide?
11.11.2020, 11:54
