EDRPOU code
Нужно производить поиск по ИНН ЕДРПОУ в системе?
Это доступно в последней версии OneBox! Установить последнюю версию системы
Need an opportunity in the Client in progress field - https://prnt.sc/uzrqx4 to search for a contact by the Code field (TIN/EDRPOU) of the contact card https://prnt.sc/uzrrj2
Now only search by name and email works, phone if checking for their uniqueness is enabled.
How to make it so that in the client field or directly in the Code field (TIN / EDRPOU) - search for a contact as by a unique value?
start indexing the EDRPOU TIN field and then there will be a search on it
To do this, add this field to the indexing of the contact fields
and wait while the search is reindexed
15.10.2020, 18:53
