Good afternoon
[file]18635[/file] The design does not transfer the field name for filtering, and the tooltip is not displayed by date
https://absstroymarket.1b.app/app/contact/
Derkach Dmytriy wrote: Good afternoon. What screen size do you have? And what hint are you talking about?
Notebook 15 inches, a hint that appears if you hover over the fields, pop-up
Derkach Dmytriy wrote: Zoom not enabled? Some input fields are too small
The design must be rebuilt and transferred, depending on the display
Do you have 120% scale enabled?
Anatoly
no, like i said, shouldn't it adjust ?
Ustimenko Igor
OneBox production wrote:
Anatoly
[file]18664[/file] no, like i said, shouldn't it adjust ?
Filters don't exactly need to be adjusted. I still can’t understand from the screen what the screen size is and why everything looks so large, if it’s not a scale, then I see this for the 1st time
Anatoly
Ustimenko Igor
Anatoly
