Completion of the action "Fill in the field of the contact card based on another field"
In the "copy from" field, you need to make it possible to specify several fields. [file]17935[/file]
Also, if we select a field with the multilist type there, it should copy all the values \u200b\u200bthat are specified in the field.
How much will it cost?
Completion of the action "Fill in the field of the contact card based on another field" In the "copy from" field, you need to make it possible to specify several fields. Also, if we select a field with the multilist type there, it should copy all the values \u200b\u200bthat are specified in the field. How much will it cost?
Ustimenko Igor OneBox production wrote: but how to write values if you have selected several fields or a multi-box field with 10 values and chose to write in the string field for example
It doesn't matter, I'll also record in the multilist. But you can write it separated by a comma or just the first one if it is written in a string. Yes. Multiple fields can be selected with multiple values.
Ustimenko Igor
then it is more logical to do this only if you have selected several fields or a multilist field - and there are several values then write them separated by commas revision 4h
revision 4h
