Filter on multiple fields not working
Here is a test contact https://box.ltec.com.ua/app/contact/13965/?tabid=5
The fields are filled in it: Type of equipment, brand, model
In the filtering panel, "Search by several additional fields" is configured for these 3 fields.
But the filter does not work for any of the field types.
Please fix it.
Пятецкий Николай Николаевич
Insiders - OneBox
And you can do what if I use several filters, then it looks for a contact in which the fields are filled in just like that.
Ato works only 1 of 4 filters. Found contacts in which the combine is filled and that's it.
12.08.2022, 13:20
https://box.ltec.com.ua/app/contact/?groupid=0&valueb11=%25D0%259A%25D0%25BE... 25D1%258B&valueb12=%25D0%2590%25D0%25B2%25D0%25B0%25D0%25BD%25D0%25B3%25D0%25B0%25D1%2580%25D0%25B4&valueOtherb13=123&valueOtherb26=1997
12.08.2022, 14:58
