Here [file]15316[/file] http://crm.tryalia.com.ua/app/contact/usergroups/setting/0/interface/# (Fig. 1) there are settings.
And here http://crm.tryalia.com.ua/app/contact/14644/ (Figure 2) [file]15317[/file] I'm trying to add something, but it just crashes and doesn't give me the opportunity to add it. Please correct.
Sukhanitsky Andrey OneBox Corp. OneBox Corp - Integrator wrote: Most likely, this is how you set up filling in the fields based on the directory, in the automation of contacts. How is it set up now?
These are new fields and have nothing to do with formulas and actions in contact automation. Otherwise, how then should it work, if without specifying conditions in the universal block, the fields are filled in correctly? It's just a bug and it shouldn't work like that.
Sukhanitsky Andrey
OneBox Corp.
And the selection from where, if this field is not connected with anything? Explain what exactly doesn't work. As far as I understand, when filling in the brand, it crashes, that is, the field becomes empty, right? Then you need to understand what actions are configured in automation. + Hiding fields won't work for multilist. If you can give me access, I will try to solve your problem, but first explain in more detail.
Sukhanitsky Andrey OneBox Corp. OneBox Corp - Integrator wrote: In the automation of contacts, are there any settings?
Yes, but they are not associated with any field at all. Moreover, automation works after saving, and I didn’t even have a save)
Sukhanitsky Andrey
OneBox Corp.
Sorry, without access I can't say more. I sent a request, on this page https://1b.app/en/partner-access/ you can allow me access, and I'll try to figure it out.
Sukhanitsky Andrey OneBox Corp. OneBox Corp - Integrator wrote: Sorry, without access I can't say more. I sent a request, on this page https://1b.app/en/partner-access/ you can allow me access, and I'll try to figure it out.
It makes no sense to understand the bug) This is either a bug or a refinement (if the functionality of checking multipoles is not meant), and I need a developer who could look and answer.
Sukhanitsky Andrey
OneBox Corp.
tryalia wrote: It makes no sense to understand the bug) This is either a bug or a refinement (if the functionality of checking multipoles is not meant), and I need a developer who could look and answer.
The functionality of checking the multilist is not implied, but this generally does not apply to the fact that your value in the field is written automatically.
The value is not written automatically, if I turn off the check and output according to the filling of the fields, then everything will be ok and it will be possible to delete the value in the field. Then, accordingly, refinement is needed so that our Wishlist would be realized :)
Sukhanitsky Andrey
OneBox Corp.
tryalia wrote: The value is not written automatically, if I turn off the check and output according to the filling of the fields, then everything will be ok and it will be possible to delete the value in the field. Then, accordingly, refinement is needed so that our Wishlist would be realized :)
This setting should not affect the filling of values in any way, only the display. If so, then it's a bug
Da Hong Pao OneBox production wrote: good afternoon. Is the problem relevant?
Yes, it's either a bug or an improvement. We don't quite understand yet.) Please take a look and let me know.
Da Hong Pao
This is due to the "Additional column display conditions" setting, it does not work adequately with the multilist. I need to rewrite, it will take 2 hours
Da Hong Pao OneBox production wrote: This is due to the "Additional column display conditions" setting, it does not work adequately with the multilist. I need to rewrite, it will take 2 hours
Let's do. Please send an invoice
Da Hong Pao
