Filter contacts for which there are no open BPs
Preferably with an indication of the period during which there were no open BPs.
14.02.2022, 15:15
You can use the filter for contacts "Filter by business process and stages (there is no business in specified process groups)" .
Here you can specify the required date range, as well as select the required BP
14.02.2022, 16:52
Yevgeny Igorevich Markov
SheBo wrote:
You can use the filter for contacts "Filter by business process and stages (there is no business in specified process groups)".
Here you can specify the required date interval, as well as select the required BP
Thank you!
15.02.2022, 11:18
Looked through. Not quite that.
I need to filter out clients with whom no work has been done for a certain period of time. All proposed solutions (and not only here) refer to the process creation date or planning date. I am interested in the absence of processes at all or the closing date of the last of them.
15.02.2022, 17:39
