OS - Improve - Select and merge at once
Sometimes you need to select two contacts in the list and immediately merge them. Can this be implemented?
For example, how can you implement:
1. If several contacts are selected, click Merge, and leave the contact search bar empty, the system will merge the selected contacts.
2. Or check the box to add "combine selected".
Thanks
the system needs a mandatory choice in which contact to move the data
and with a simple selection, you can’t understand this
31.01.2022, 02:23
OneBox Corp - Інтегратор
Ustimenko Igor
OneBox production
This is how it works with goods, it combines with the first one on the list
31.01.2022, 02:49
Sukhanitsky Andrey
OneBox Corp.
Integrator wrote:
Ustimenko Igor
OneBox production
it's super obscure
31.01.2022, 03:02
Ustimenko Igor
OneBox production
OneBox CTO wrote:
Sukhanitsky Andrey
OneBox Corp.
Integrator wrote:
Ustimenko Igor
OneBox production
it's super obscure
Probably just below the search bar to show the selected contacts and prompt the user to check which contact to move the data.
31.01.2022, 10:11
something like that
01.02.2022, 14:53
Ustimenko Igor
OneBox production
OneBox CTO wrote:
I will think
did you think?
18.02.2022, 11:47
