Customization in special prices
In Special prices in the product card there is a setting Special prices relative to the price level
You can make a setting here to specify the product category and the price level for this category.
I'll give an example:
There is a client, he has a price level in the contact card Level 1
In special prices we indicate for the category of goods Test Category Price level 2
We create an order in which there are 2 products and one of them with Test Category
Here, Price Level 2 should be applied to it, and for the first product Price Level 1 from the customer card.
Can this be improved
Hello. Throw off the link where you set these prices now
24.09.2021, 17:26
anonymous duck
OneBox production
Now there is no such setting, so I do not install it))
So I clarify to add it here https://optmaster.crm-onebox.com/admin/shop/users/44183/discount/
24.09.2021, 17:29
Try to do it through "Special prices relative to the price level" + Select a category + Select a price level + 0 or 00 as a discount percentage
24.09.2021, 17:33
anonymous duck
OneBox production
The problem is that if you put 0, nothing is saved
24.09.2021, 17:34
0.00000000001 for help))
24.09.2021, 17:41
Hello. The option described above only works if the product is added directly to the order itself. If the order came from Prom.ua, then the prices are set as normal, special prices do not apply. Do you need any additional settings?
11.08.2022, 20:18
