Refinement configure contact search by phone number fragment
Colleagues, good afternoon!
Please rate the improvement. It is necessary to implement the ability to search for a contact card in the database using a fragment of a phone number. It can be implemented through a general contact search string or through an additional field.
For example, in the card number tel. 89006386348, the employee enters 86348 in the search bar in the contacts application and the box throws up all the contact cards where there is such a sequence in the phone number.
you can modify the setting so that there is a partial search by phone
so if you enter less than 10 digits and more than 5, for example, then the system automatically understands that this is a partial search and searches for part of the phone
if it fits then 3h revision
09.09.2021, 14:20
