Category is duplicated in Eney supplier data
In the Eney supplier data, the Bags category is duplicated (multiplied), creating multiple subcategories, including nested ones. This category is new for the supplier, it appeared in 2020: http://eney.com.ua/bags/
If you use the "Import data from the ENEY provider" automatic action, categories from that provider are not loaded into the system. Also, this action does not add or update a category for a product. Products from the category you specified enter the system and are updated.
Could you tell me how you interact with this supplier
19.05.2021, 13:18
