When automating once a year, data is incorrectly adjusted
Universal product import (xml/json) (Svit mtx 7:00) (take place at 7:00 https://prnt.sc/10bytf3)
https://ua.toolsworld.com/yandexmarket/8302c78c-0049-4052-833c-13147d70d0db.xml
Є goods https://rovo.org.ua/admin/shop/products/31531/edit/
(code 576169 according to how it is updated https://prnt.sc/10byn73)
in which field https://prnt.sc/10byl0g
are updated incorrectly
https://prnt.sc/10byrw8
May I look green
and how to update the chervonim
https://rovo.org.ua/admin/shop/products/31531/history/?userid=&systemchange=1&filter2_key=valueold&filter2_type=search&filter2_value=&filter3_key=valuenew&filter3_type=search&filter3_value=&fieldkey=&filtercdatefrom=&filtercdateto=
when updating manually, it currently sets the correct price and quantity
perhaps at 7 am in the price list are not "correct" values?
I'll put it at 19:00 at the file price virna https://prnt.sc/10dt378 Only the quantity has been updated, the price is not correct https://prnt.sc/10dt4mg When manually updated, it is correct instead of the same What's the problem??? її need to fix an obvious bug
added logging for product price update do not change the actions, we will wait for the scheduled update and in the morning I will look at the logs of what was updated and from where
if it were obvious, we would not waste time on this topic
While the reason for this is not clear to me, it seems that the update is supposedly happening either from a different price list, or the product is re-found according to other data. I recorded your appeal on myself, as there will be some result of the analysis - I will give feedback here.
Buchkovsky Rostislav Vasilievich wrote:
Tezh same
[file]4346[/file]
I launched an update of only the above product https://rovo.org.ua/admin/shop/products/31531/edit/ only for the 1st automation - the price was correctly set to 192.84, as in the price list. After that, I launched all the hourly import automation (only for this product) - the price did not fray at all. That is, at the moment, as I understand it, the problem is probably not relevant.
