I set automatic actions, the product is added, but many positions are duplicated
for example https://cabinet.tehnolavka.com.ua/admin/shop/products/?filtername=&filterid=&filterarticul=&filtercode1c=dclink-267934&filterbrands=&supplierid=&filtercdatefrom=&filtercdateto=&filtersuppldatefrom=&filtersuppldateto=&categoryid=&searchLine=
here in general 3 https://cabinet.tehnolavka.com.ua/admin/shop/products/?filtername=&filterid=&filterarticul=&filtercode1c=dclink-337470&filterbrands=&supplierid=&filtercdatefrom=&filtercdateto=&filtersuppldatefrom=&filtersuppldateto=&categoryid=&searchLine=
The action, when properly configured, does not duplicate products. Most likely, you previously set the settings "Do not search for matches by article number" and "Search products only by article number" at the same time, which created a "conflict of interest" and thus the product was not searched by article number for the first setting and was created. Checks have been rewritten so that even if the setting "Do not search for matches by SKU" is set, then "Search products only by SKU" will always search for goods by SKU.
Initially, there were these settings https://prnt.sc/xggzjb Yesterday I noticed that there are duplicates and checked the box "Search products only by article number", I thought it would be added without duplicates, but it didn't help. And your theory is wrong, I did not do that
Tyndyk Maxim Vadimovich Administrator wrote: Now there are new duplicates? Let's check on the example of some product
I deleted all the previous ones, I decided to import everything again with these settings https://prnt.sc/xlqxbn
Reappeared https://prnt.sc/xlxtat
Here is a link to the products https://cabinet.tehnolavka.com.ua/admin/shop/products/?filtername=&filterid=&filterarticul=&filtercode1c=dclink-281011&filterbrands=&supplierid=&filtercdatefrom=&filtercdateto=&filtersuppldatefrom=&filtersuppldateto=&categoryid=0&searchLine=
Products are created in the same second - this means that 2 hourly crowns worked on the server in parallel (the difference in launch is 4 hours). I can assume that while 1 kroner was waiting for data in response (there may be restrictions on receiving data) - the second one started, finalized until the moment when data was received from dc-link - and their server gave data to both requests simultaneously - and parallel download began. Now I launched cron for the test, I'll see how long it will work
Good afternoon. Reappeared https://cabinet.tehnolavka.com.ua/admin/shop/products/?filtername=&filterid=&filterarticul=&filtercode1c=dclink-324982&filterbrands=&supplierid=&filtercdatefrom=&filtercdateto=&filtersuppldatefrom=&filtersuppldateto=&categoryid=&searchLine=
Tyndyk Maxim Vadimovich Administrator wrote: Added protection against duplicate watch crown. Apparently dc-link keeps the connection for hours and does not give the file.
Thank you! Previously, I already unloaded goods from dc-link, on the previous version of the box, everything went fine. In theory, there may be some kind of bug in the new version of the box?
Thank you!
Kachanovsky Andrey Vladimirovich wrote: Previously, I already unloaded goods from dc-link, on the previous version of the box, everything went fine. In theory, there may be some kind of bug in the new version of the box?
No, previously dc-link apparently did not make such restrictions / delays in issuing a file.
Tyndyk Maxim Vadimovich Administrator wrote: No, previously dc-link apparently did not make such restrictions / delays in issuing a file.
And if you do not activate these settings https://prnt.sc/xrq2nj, will the search be performed by the supplier code?
Kachanovsky Andrey Vladimirovich Client wrote: And if you do not activate these settings https://prnt.sc/xrq2nj, will the search be performed by the supplier code?
tries to find first by article, then by code, then by supplier code
All the same, duplicates appear =
