Da Hong Pao OneBox production wrote: Good afternoon. Go to the appropriate application, there may be information about this. You can also see for a product whether it has a supplier.
There is no information about this in the applications. Previously, it was possible to look in the logs by erc, but now I can’t find it. Item data is not updated. I looked through. So I need to see what the problem is
Da Hong Pao
Good afternoon. Everything does not work out with the automation of the South and ERC http://domovoy.kr.ua/admin/shop/products/112511/edit/ - product on the site https://b2b.yugcontract.ua/product/6773489 - supplier's product. the supplier has it in stock, on the site it says - out of stock. How does product synchronization work? If I add "yugcontract-" to this product in the supplier code, then it says out of stock, if I leave only the code 6773489 - in general, the Automatic integration process ignores this product, does not see it. How to set it up so that goods are automatically processed?
Good afternoon. I wrote a message with "upnul" in this thread by mistake, I wanted to go to another Regarding the supplier, when requesting the "https://soap.yugcontract.ua/API#GetPrice" method, we get the error "You do not have access to this method. Please, ask your responsible manager". Write a message in support of the South contract to give access to the method. erc receives the file, in theory the update should go fine.
And, they turned off the api in general the old one. I forgot about that, sorry. https://1b.app/en/app/supplierugcontract2/ here is a new application for working with this supplier. In the old one, we will soon write that the South Contract has disabled the old api and the action is no longer working.
The application is only for os, I advise you to switch as soon as possible, since almost nothing is updated for mvp and soon there will be no support at all.
in the list of your boxes, you can order a transition. You can also write or call the contact details https://1b.app/ru/partner/onebox-corp/ and clarify what you are interested in switching to os, they will tell you everything in detail about os, how the transition will be carried out and what you will need.
[file]17085[/file] in the list of your boxes, you can order a transition. You can also write or call the contact details https://1b.app/ru/partner/onebox-corp/ and clarify what you are interested in switching to os, they will tell you everything in detail about os, how the transition will be carried out and what you will need.
