Estimation of the road for the acquisition of prices
Evaluate, be kind, the possibility of automatically populating the field "Text of the presence of the supplier of the product" (or "Availability of the supplier") when the price of the supplier is set to the value (which cannot be in the price)
(similarly adjusted in the automatic mode "Universal product import (xml/json)" - )
Good afternoon. Do you need to fill in the availability text if the product is not in stock in the price list or always?
16.07.2022, 19:27
If the position is in the price list, then for it you need to store the field in the custom values (columns with these data in the price list are not available - I wrote a little bit in the request)
19.07.2022, 15:15
You can make sure that all products that are in the price list have the "Supplier Availability Text" (this field) when loading the price list. The default value will be set when loading the supplier's price list along with other settings. Takes 3h.
19.07.2022, 17:57
