I encountered a problem with the RRC in the price. The supplier has an RRC not for the entire product, but only for some.
When loading the price, the RRC specified the price, the price is still recalculated according to the formula that I specified in the recalculation of prices and availability.
If you use the function "Hardly set RRC on all loaded goods" when loading the price, then the price is for goods with RRC, and if the product does not have RRC, then there is no price (screen 1) [file]14849[/file] . How to make the RRC price be for the product, and where it is not - recalculated according to the formula?
Good afternoon. I encountered a problem with the RRC in the price. The supplier has an RRC not for the entire product, but only for some. When loading the price, the RRC specified the price, the price is still recalculated according to the formula that I specified in the recalculation of prices and availability. If you use the function "Hardly set RRC on all loaded goods" when loading the price, then the price is for goods with RRC, and if the product does not have RRC, then there is no price (screen 1) . How to make the RRC price be for the product, and where it is not - recalculated according to the formula?
Good afternoon. When loading supplier prices, you can load both the supplier's price and the RRC in separate columns. And further, depending on the settings of price conversion and availability - for goods for which the supplier's RTC is specified - the supplier's RTC will be selected, and for others - a recalculation according to the supplier's price.
Maksym Vadimovych Tyndyk OneBox production wrote: Good afternoon. When loading supplier prices, you can load both the supplier's price and the RRC in separate columns. And further, depending on the settings of price conversion and availability - for goods for which the supplier's RTC is specified - the supplier's RTC will be selected, and for others - a recalculation according to the supplier's price.
When recalculating prices, the price is still set according to the formula
