Does not filter by suppliers in goods and stocks
Made acceptances from suppliers. But when I wanted to see what was left of these suppliers, the filter by suppliers does not work https://prnt.sc/uiqart
can you provide a link to your box?
17.09.2020, 10:13
https://b2bhub.crm-onebox.com/
17.09.2020, 10:16
most likely I am due to the fact that you have not added this supplier to the product card - https://prnt.sc/uiqw02 (I opened the first arrival from this supplier, and in none of the products I saw the link to the supplier - https://prnt.sc/uiqvhd ),
17.09.2020, 10:35
Thank you. understood
But it turns out that it is impossible to import a product where each product has its own supplier?
17.09.2020, 10:50
import or post? you can import, even when importing products from xls, there are fine settings for loading filters and suppliers -
https://prnt.sc/uirdmq
17.09.2020, 11:12
Alexander wrote: But it turns out you can't import goods where each product has its own supplier? Import or post? you can import, even when importing products from xls there are fine settings for loading filters and suppliers - https://prnt.sc/uirdmq
Sure, we'll try it now. THANKS
17.09.2020, 11:17
