In product automation, there is an action to be triggered when saving products "Sum the numeric representation of the availability of product suppliers and write in an additional field."
The action does not work if this product is not available in the supplier's price list file when loading the supplier's price list via the Logistics->RFP menu item.
Those. The goods were in stock at the supplier, but all sold out. As a result, there is no line with this product in the new price list of the supplier. In this case, the system in the Suppliers tab for the product writes "Not in the price list" (in the Availability from the supplier field) http://i.imgur.com/J9IeaXl.png. In this case, the automation action "Sum the numeric representation of the availability of product suppliers and write in an additional field" does not work.
If there is a line with a product in the supplier's price list, but it has zero availability, everything
Good afternoon. In product automation, there is an action to be triggered when saving products "Sum the numeric representation of the availability of product suppliers and write in an additional field." The action does not work if this product is not available in the supplier's price list file when loading the supplier's price list via the Logistics->RFP menu item. Those. The goods were in stock at the supplier, but all sold out. As a result, there is no line with this product in the new price list of the supplier. In this case, the system in the Suppliers tab for the product writes "Not in the price list" (in the Availability from the supplier field) http://i.imgur.com/J9IeaXl.png. In this case, the automation action "Sum the numeric representation of the availability of product suppliers and write in an additional field" does not work. If there is a line with a product in the supplier's price list, but it has zero availability, everything
Hello, in my opinion, it is quite logical - the product is not in the supplier's price list, which means that the product and, accordingly, the automation actions for the product do not need to be called. If you need automation to be called after loading the supplier's price list for all products (the list of suppliers of which has the current supplier), this can be done in 1 hour by forcibly going through these products and calling all automation actions for them.
