Delete all positions of the supplier with which we no longer work
Hello, please tell me how to delete all the positions of a supplier with whom we no longer work. The supplier was deleted, the positions in the binding were also deleted, but those positions that were previously BOUND still loom.
Hello, if you have the supplier "Acoustics (API)" displayed in your products, then this is most likely due to the fact that you specified this supplier in the automatic action of importing products as a constant http://joxi.ru/l2ZXoVauzX9L5r
Change this setting to the code of an existing supplier and the products will be loaded by the required non-remote supplier
By default, vendor products are removed when a vendor is uninstalled. In your case, it happened, cleared, but loading by settings loaded exactly according to the specified provider
After changing the supplier, write here - I will delete the records of this supplier from the supplier's products.
15.09.2020, 13:05
Hello Maria. We are talking about the South of the stock, the supplier was filled in manually without api.
16.09.2020, 13:11
This provider is not remote on your system
16.09.2020, 13:16
And how to remove it then correctly?
17.09.2020, 14:04
Go to the supplier, click on the delete button. The supplier will be marked as deleted, as well as the products that are linked to it, this link will be deleted
17.09.2020, 17:00
