Urgently. Problem with unloading at the outlet.
Good afternoon. There was a problem uploading to the outlet. Only category IDs and photos are uploaded. In other uploads, everything is the same . At the same time, we did not change anything in the settings.
https://superero.crm-onebox.com/admin/auto/action/hour/edit/
What could be the problem?
Your problem is that you first set up the correct upload action for the Rozetka ogos price platform, which uploads the file correctly - and then an action is added for uploading for all price platforms, but the fields are not configured correctly - so only fields that are not depend on settings.
If the action should not work - turn it off - and it will not "overwrite" the files.
27.07.2021, 13:32
