There is a problem
[file]22178[/file]
A new person knocks on the Telegram bot: https://t.me/BalistykaUA_Bot
[file]22178[/file]
The box does not create a contact card for this person and task.
[file]22178[/file]
According to old users, this same bot works and everything is OK.
[file]22178[/file]
Here is an example of a problem: balistyka.1b.app/56016/
[file]22178[/file]
Configured the action Turn Telegram message into a process to create a task:
[file]22178[/file]
balistyka.1b.app/app/automatization/minute/edit/
[file]22178[/file]
Please help to fix
[file]22178[/file]
This topic is paid
[file]22178[/file]
[file]22178[/file]
Good day! Try checking the following options: 1. Contacts application - Other settings - the "Allow adding a user without contact data" check box must be checked 2. In the integration settings /app/telegram/appsettings/, try to set the item "Unsubscribe" - "Save" - then the item "Subscribe" - "Save"
Good day!
Bushuev Sviatoslav Yuryevich VANBOX CORP wrote: Good day! Try checking the following options: 1. Contacts application - Other settings - the "Allow adding a user without contact data" check box must be checked 2. In the integration settings /app/telegram/appsettings/, try to set the item "Unsubscribe" - "Save" - then the item "Subscribe" - "Save"
thank you Everything is O.K
VANBOX CORP wrote:
Good day!
thank you
Everything is O.K
