https://zhiraf.crm-onebox.com/admin/customorder/order/10221/edit/
[file]5100[/file]
Copies appeared? Even so often trapleyaetsya.
Obov'yazki in the history are formed correctly, payment will come in the same time correctly. Redaguvan nothing happened. All transactions are in UAH.
Copies appeared? Even so often trapleyaetsya. Obov'yazki in the history are formed correctly, payment will come in the same time correctly. Redaguvan nothing happened. All transactions are in UAH.
Hello. In the action of accruing obligations "Install/update our goiters to the client" in the procedure, check the box "Indicate goiters' dues according to the amount of consideration/appropriation of products in the process"
https://zhiraf.crm-onebox.com/admin/customorder/order/10702/edit/
Our obligations: -0.01 UAH
I want to put a tick on the procedures and on the steps in the stage.
