it is impossible to set a currency rate greater than 9999 for the base
I'm trying to set the exchange rate 10550 sum for 1 dollar. The value is not saved and the value 9999.999999 is always output instead. if I enter a value less than 9999 , then it is saved correctly
Apparently there is a limit on the maximum value of the exchange rate. I ask you to remove it, because in this case it becomes impossible to work with exchange rates
hello, we have accepted your question
05.04.2021, 17:37
added the ability to save 5 decimal places in exchange rates
07.04.2021, 10:47
