Good afternoon. Your question is not entirely clear. You want to add some additional variable to yourself "in words". If so, please indicate which one - I can evaluate the revision.
Well, let there be an expected payment.
you can then explain the operation of the action "Generate pending payment"
https://adapter.crm-onebox.com/admin/shop/workflowstatus/106/action/new/
for some reason the sum is 0 all the time
https://adapter.crm-onebox.com/admin/customorder/order/7456/payment/
you need to figure out how much the revision costs the amount of the process in words in Ukrainian and the image of the barcode of the shipping invoice too (did not find such a variable)
it will take about half an hour to add any numeric variable from the list of variables in the document template in words Delivery note barcode - we don't have a field with that name. Perhaps you mean some kind of pdf with a new mail invoice with a barcode or something else, please specify what you want to display in the document (a link to the process where it is and a screenshot from where to get it will suffice).
so what? you have there all the characteristics of the goods are printed with a barcode. but for some reason it doesn't. already used to make it possible to pass any variable as an argument.
so what?
Bodyako Dmitry dev wrote: do you want to just take the number 050....17 and sew it into a barcode?
why sew? display as a barcode encoding, preferably which new mail uses.
Bodyako Dmitry
why sew?
revision the amount of the process in words in Ukrainian (as on the screen) the amount of obligations in words in Ukrainian (as on the screen)
and the barcode of the delivery note from the process (the encoding that the new mail uses)
revision
[file]2930[/file]
Good afternoon. Variables you need: 1.ordersumtext_ua 2. ourObligationBalance_ua 3. deliveryNoteBarcode_svg or deliveryNoteBarcode_ean13 In order to have the images in the 3rd paragraph of the size you need, put the variables in the div at the desired size in the document template.
1.ordersumtext_ua
barcode not working
https://adapter.crm-onebox.com/admin/customorder/printing/?moveids=8557,8460,&ordertype=order&printbypriority=&printbyorder=
[file]3009[/file] - an error pops up.
[file]3010[/file]
Good afternoon. I personally tested all 3 variables on my document, you probably made a mistake when writing the variable. Please reset the link to the process and document template you are using.
