1. You can uncheck the Allow changing the payment date checkbox, then the system will not check the payment date when adding 2. If an error occurs, you can click save again and the system will automatically set the current date 3. If you add a payment for a long time (more than a minute), you can increase the time (date) of the payment by +1 minute
if you uncheck the box, then there is no date field when adding a payment And if you uncheck this box, then it will not be possible to change the payment date?
There are already requests from 3 users:
https://crm-onebox.com/en/support/finances/4743-otklyuchit-zapret-na-sozdanie-platezhey-zadnim-chislom/
https://crm-onebox.com/ru/support/business-processes/4425-bag-deystviya/
https://crm-onebox.com/ru/support/finances/4842-ne-sozdaetsya-platezh-s-proshloy-datoy/
return as it was
