How to choose by date of payment? I'm trying to fix it, but it doesn't work, and I'm still trying to select all payments
integrator
integrator.com.ua
in the financial block /admin/shop/finance/
choose filter
did you choose that?
27.11.2020, 11:57
Filter required for API.
Feeds the programmer which sets up synchronization for 1s
27.11.2020, 15:31
integrator
integrator.com.ua
wow, we need more food:
pass the API documentation to the programmer https://box.webproduction.ua/doc/1068/
in separate payments є "Parameters for receiving all payments:"
cdatefrom
cdateto
27.11.2020, 19:19
Is filtering required by the finance-get API?
30.11.2020, 09:52
integrator
integrator.com.ua
Buchkovsky Rostislav Vasilievich
if you don't understand the power - can you give the programmer access to the forum, high power yourself?
30.11.2020, 10:09
Axis zapit https://rovo.org.ua/api/1c8x/finance-get/?
here youmu needs a filter by dates
30.11.2020, 13:56
integrator
integrator.com.ua
such a request is incorrect, missing authorization data and not receiving the correct way /api/payment/balance/get/
I recommend to know a programmer who works with API.
I can’t give more advice here, because I’ll have more prompting to ask with a valid API key.
30.11.2020, 14:05
Zapit Correct https://prnt.sc/vsvl3w
Keys,
Just needed Filter
Will I need to send a common request with a key?
(Later I remember)
30.11.2020, 15:38
integrator
integrator.com.ua
I already wrote about filters:
"in separate payments" "Parameters for receiving all payments:"
cdatefrom
cdateto"
the request says cdatefrom and cdateto?
30.11.2020, 16:01
30.11.2020, 17:42
cdatefrom
cdateto"
Don't filter
https://rovo.org.ua/api/1c8x/finance-get/?login=ros&password=62c8ad0a15d9d1c...
30.11.2020, 19:07
integrator
integrator.com.ua
cdatefrom
cdateto"
Don't filter
Can't give a date in the request cdatefrom
01.12.2020, 11:13
integrator
integrator.com.ua
your show request can have two parameters cdatefrom and cdateto
01.12.2020, 20:24
So do not filter
does not work. Here is the request: https://rovo.org.ua/api/1c8x/finance-get/?login=ros&password=62c8ad0a15d9d1c...
Pulls all payments for the entire period
02.12.2020, 11:32
integrator
integrator.com.ua
I don’t understand why you didn’t want to do it yourself, as it is written in the API, the axis of the request:
https://rovo.org.ua/api/payment/get/?login=ros&password=62c8ad0a15d9d1ca38d5...
all payments for today's appointments https://prnt.sc/vugl6e
Change your login-password quickly so that such data is not available online.
02.12.2020, 18:46
The programmer has created a dorobka according to that format.
I have already ordered a box. So you can use.
04.12.2020, 11:03
integrator
integrator.com.ua
and more than enough standard methods of documentation.
and so i didn’t block access to this API - you can’t just take data, but add chi to see. Take it, please.
and indicate to the top comment that the wine is correct.
04.12.2020, 11:32
