Nova Poshta: Shipped not in a box
Есть запрос на разработку функционала?
Создайте топик на форуме и получите оценку разработки от партнера-разработчика! Создать топик
in the NP there was such an option "Redirection not in the box": https://prnt.sc/v4m5w8
the client will ask if it will be possible to check this box in integration with Boxing
Hello. It all depends on whether New Mail makes it possible to add this parameter to the api. If it does, it will take us to finalize the transfer of the checkmark when manually creating ttn 1h
22.10.2020, 17:00
integrator
integrator.com.ua
Bodyako Dmitry
axis here є API documentation https://devcenter.novaposhta.ua/docs/services/556eef34a0fe4f02049c664e/operation...
Formation of a request for the creation of "EN" with the service "Departure without a box"
The service is available for order in case of creating a document with the following characteristics: one of the sides of the shipment (or one piece) from 40 to 120 cm and the weight of the shipment (or one piece) from 2 to 30 kg.
The order of the service is possible:
Without transferring seat dimensions using the parameter:
"SpecialCargo":"1", - "Departure without a box" "1" - YES "0" - NO.
With the transfer of seat dimensions using the parameter:
"specialCargo":"1", - "Departure without a box" "1" - YES "0" - NO.
evaluate whether weasel the door not for manual, but for diї Automatically create TTN through the subfield in the integration of NP.
05.11.2020, 11:02
Those. in the integration settings, select the additional field. If the additional field is filled in the order, the action of creating a tn is transferred to the NP "Send without a box" for all products. Takes 2h.
05.11.2020, 11:16
integrator
integrator.com.ua
Bodyako Dmitry
for the client to come, put up be weasel rahunok on TOV RS-FORT
05.11.2020, 16:49
integrator
integrator.com.ua
Having paid for the client today, can you launch it into the robot?
10.11.2020, 13:33
integrator
integrator.com.ua
Vіtannya, according to NP, I still don’t get the boxes - the integration axis in the client https://prnt.sc/vko3k8
17.11.2020, 12:36
the client has accepted, everything is working, such. can i have a link for tea?
13.01.2021, 18:33
Susyak Igor
https://www.liqpay.ua/ru/checkout/card/i40375101891
13.01.2021, 19:46
