Well, something needs to be done...
http://prntscr.com/v9djs5what should I answer the tax why do I have two payments in the check?
the minimum effort is to refine the creation of a check, which instead of the payment amount, give the process amount.
for example
- if the payment amount is less than the process amount, then send the process amount.
or
- if the payment amount is less than the process amount and the status is "paid", then send the process amount.
or suggest another solution?
