Payment is not linked to the process by external process id
try to put ordercode1c$ instead of ordercode1c
20.08.2024, 17:54
Maria
Thanks, it worked! What kind of operator is this?
20.08.2024, 18:11
$ sign to take the value to the end of the line, in your case you need to use the entire comment to the payment for the search
21.08.2024, 09:38
Why does it search for the main process number without this sign?
And please tell me what does "until the end of the line" mean? In the comment there is only the external process id, without $ only the first character is processed?
21.08.2024, 12:10
The process number is a number and when we look at the orderid, we look for a number. For the external code, different letters can be used, not just numbers
This template allows you to search by part of the payment comment using regular expressions. For example, to take everything after # or before the comma, etc. In your case, it was necessary to use the entire comment for the search, with which $ helped
Donats 1
3 USD from Родион
21.08.2024, 17:44
Got it, thank you very much!
21.08.2024, 21:18
There was an almost similar error, I work with an affiliate project and I constantly need to track payments and have access to all data related to transactions that are carried out on the site and I don’t really want to receive a bug like this, especially when you have more than 100 orders a day and you run out reporting needs to be reset. Oddly enough, it was the trade that helped me fix this bug, so that you understand, in general, help me with the solution of this bug on the ultra-thematic site, forum, union https://cpa.club/companies/pin-up-partners/ where I always sit to get new knowledge in my field, but there on the forum some programmers helped me fix it by throwing me a link to this topic on the forum, thanks for solving the problem!!!!
02.12.2024, 17:57
