There was such a problem. Does not withdraw payments from 3 FOPs from privat24, payment accounts: Rs-FOP Haydak N.S. , RS-FOP Golovan I.E. , RS-FOP Perekhrest G.B. Despite the fact that all FOPs that were created before them and all that were created after them are adequately tightened. Just like all the automations for them, they are filled out identically and the corresponding keys and tokens are there. We have already contacted Privat Bank, they said that everything is correct with them. Box address https://sale.brille.ua/
Please advise what the problem might be.
There was such a problem. Does not withdraw payments from 3 FOPs from privat24, payment accounts: Rs-FOP Haydak N.S. , RS-FOP Golovan I.E. , RS-FOP Perekhrest G.B. Despite the fact that all FOPs that were created before them and all that were created after them are adequately tightened. Just like all the automations for them, they are filled out identically and the corresponding keys and tokens are there. We have already contacted Privat Bank, they said that everything is correct with them. Box address https://sale.brille.ua/ Please advise what the problem might be.
Good afternoon. In your actions that cost once per minute, you have selected “Startup time” “Once per hour”, select there once a minute or once every 5 or 30 minutes, then it will work. Running once per hour only works if the action is set to automate once per hour.
In your setting "If the client is not found in the system, then make the payment on "for RS-FOP Gaydak N.S., RS-FOP Golovan I.Є. only the contact name is indicated, for correct operation you must select the desired one from the prompt For Crossroads, this field is empty and if it does not find a client using other settings, the payment will not be created
