In connection with the rebranding, we will also change the endopoint to the PartnerInstallment service in a productive environment,
to which partners are connected already after passing the test.
"old" endpoint - https://api.alfabank.kiev.ua
new:
https://api.sensebank.kyiv.ua
Good day
Can you replace?
In connection with the rebranding, we will also change the endopoint to the PartnerInstallment service in a productive environment, to which partners are connected already after passing the test. "old" endpoint - https://api.alfabank.kiev.ua new: https://api.sensebank.kyiv.ua Good day Can you replace?
Hello
To change the endpoint, you need to open the "Alfa-Bank payment by parts" integration settings (for your version of the system, it will be available at /admin/shop/integrations/payparts-alfabank-ua-integration/control/)
and change URL from: https://api.alfabank.kiev.ua:8243/api/PartnerInstallment/v1.0/ to https://retailapi.sensebank.com.ua:8243/api/PartnerInstallment/v1.0/
