In actions related to copying or writing variable values from the `Directory of Variables`, the value of the variable `[clientobligationTotal] - Client Obligations (balance)`, the name of the variable itself is written and not its value.
Bodyako Dmitry Employee wrote: try using {|$clientobligationTotal|} . Those. most likely you just write the variable incorrectly
Tried. To no avail.
Tried. To no avail.
Hello! On this topic: I need to show the client's obligations in the "Startup Form" of the process. I wanted to copy it in the additional field. Doesn't copy. Maybe someone knows how to do it? Thanks for the answer!
Hello!
Didik Igor Client wrote: Bodyako Dmitry Employee wrote: try using {|$clientobligationTotal|} . Those. most likely you just write the variable incorrectly Tried. To no avail.
please give a link to the stage where it is configured and an example of the process to see the result of the work
Didik Igor
Bodyako Dmitry Employee wrote: Didik IgorClient wrote:Dmitry Bodyako Employee wrote:try using {|$clientobligationTotal|} . Those. most likely you just write the variable incorrectly Tried. To no avail. Please give a link to the stage where it is configured and an example of the process to see the result of the work
http://joxi.ru/n2Y6LQBteG5EWA
http://joxi.ru/KAx6pvXtKn8Nnm
Didik Igor Client wrote: Bodyako Dmitry Employee wrote:Didik IgorClient wrote:Bodyako Dmitry Employee wrote:try using {|$clientobligationTotal|} . Those. most likely you just write the variable incorrectly Tried. To no avail. Please give a link to the stage where it is configured and an example of the process to see the result of the workhttp://joxi.ru/n2Y6LQBteG5EWAhttp://joxi.ru/KAx6pvXtKn8Nnm
Hello! Do employees have a reaction to solving this error?
Hello!
Once again, hello everyone! Found a solution to this problem: Inserted action http://joxi.ru/V2Vz6NpikEoal2 In this action, the variable `client obligations (balance)` is [client_obligationClientin] (this variable is described as - [clientobligationTotal] in the reference book) and I write it in the additional BP field. It works now!
It works now!
