OS write the custom value in the exchange rate variable
The client's base currency is USD
exchange rate to the hryvnia, respectively, in the form of 0.0242
it is necessary that the usual rate of 40 can be recorded in the additional field, from which I should copy the already divided number into the field [currency_rate_1]
the required action of the type Copy the value of the additional field to the process field is obtained, but there is no field [currency_rate_1] - Currency rate (UAH) https://www.screencast.com/t/jQf8TBGctl
if this is an improvement, please rate it
Good afternoon. I do not quite understand why you are not satisfied with the standard rate of the system in the order? In your system, the exchange rate in the system should not be 40 for the hryvnia, but 0.0242 by default, and 1 for the dollar. Is this not the case now?
30.08.2022, 18:40
that's right, this is the norm for the USA.
but some of the employees bring goods to Ukraine and they are not used to the exchange rate of 0.0242 - I created a custom field with the exchange rate, where they will enter, for example, 40, and I will already calculate our internal one.
so what is the possible option other than manual calculation of the rate?
30.08.2022, 19:05
now it is impossible to change the course of the process. If you need to do this, you can register the exchange rate for the desired currency in the specified or any other action, it will take 2 hours.
30.08.2022, 19:15
Good afternoon. Action "Update the process currency rate from an additional field". It will appear on os tomorrow morning.
06.10.2022, 15:44
greeting
could you check on a real example:
here is the process https://swn.1b.app/16/
put a calculation for USD on the procedure https://swn.1b.app/app/workflow/4/procedure/1/ yes https://take.ms/56b5O
the result of the action works, but the sum of the exchange rate is in UAH when the Currency of the process field is: USD https://take.ms/FsqCh
07.10.2022, 14:10
Always test everything regarding currencies on new orders. In this order, the dollar exchange rate was 0.024390, and the hryvnia exchange rate was the same as you set in the action. That. it turned out to be 1 to 1, and therefore the amounts were the same when converted. I removed the incorrect dollar rate and everything was fine
07.10.2022, 14:23
