https://g-arm.1b.app/app/payments/3/control/ I want to assign process 23 to this payment
I enter the process id in the "Binding to the process" field, the download is in progress, but the process is not pulled up
https://g-arm.1b.app/app/payments/3/control/ I want to assign process 23 to this payment I enter the process id in the "Binding to the process" field, the download is in progress, but the process is not pulled up
Sukhanitsky Andrey OneBox Corp. OneBox Corp - Integrator Named License wrote: put a space after 23, search works from 3 characters
it helped to add two points, like this 23 .. is it possible to fix this somehow, so that the search would be from two characters?
Sukhanitsky Andrey
OneBox Corp.
Morozov Sergey Sergeevich Sergey Morozov wrote: it helped to add two points, like this 23 .. is it possible to fix this somehow, so that the search would be from two characters?
finalize, I think it is possible, but this is a load on the search, more options need to be sorted out
it makes no sense to refine something like that, because such processes will disappear as soon as you finish testing the system) you can still search like this, i. by process name or other fields. If you know the process id, it's easier to add it directly from the process
it makes no sense to refine something like that, because such processes will disappear as soon as you finish testing the system) [file]16846[/file] you can still search like this, i. by process name or other fields. If you know the process id, it's easier to add it directly from the process
