https://datapoint.center/
There are 4 payment methods [file]15724[/file]
2 of them are downloaded from the site, but we don't want to use them. When we delete them or change the hidden one, the order arrives and the hidden checkbox is removed and it is visible again. Loaded via Import processes from CS-Cart
A solution is needed so that these methods are not displayed in the list. It is possible to finalize the comparison of payment methods, or another option. Please advise
https://datapoint.center/ There are 4 payment methods 2 of them are downloaded from the site, but we don't want to use them. When we delete them or change the hidden one, the order arrives and the hidden checkbox is removed and it is visible again. Loaded via Import processes from CS-Cart A solution is needed so that these methods are not displayed in the list. It is possible to finalize the comparison of payment methods, or another option. Please advise
Let's make the default method in action, and below the comparison of the name from cscart (you enter it yourself in text) and on the right, the choice of which method to choose in the box. If none of the methods is found, the default one will be set. 2h
anonymous hamster OneBox production wrote: Let's make the default method in action, and below the comparison of the name from cscart (you enter it yourself in text) and on the right, the choice of which method to choose in the box. If none of the methods is found, the default one will be set. 2h
Then immediately you need to do for the method of payment and delivery. How long will such a revision take?
anonymous hamster
