change currency
Есть необходимость изменения валюты в системе?
Создайте топик на нашем форуме и опишите поставленную задачу - партнер уведомит о рисках связанных с изменением и поможет в решении это задачи! Создать топик на форуме
in this video https://www.youtube.com/watch?v=dKArvhlMVqk&t=67s
it is said that there is a base currency of the system, and it cannot be changed manually and you need to write to those support.
How to do it now if you need to change the base currency to the ruble?
Write to the forum, indicate the box in which you need to change, but mb confirmation of the client is necessary
The client can create this task himself or simply unsubscribe in it, which confirms
It used to be free
21.09.2020, 16:09
The base currency of the system can only be changed (set) when the OneBox is new (clean).
In the existing system, in which there is at least some data (goods, warehouse, finance), this is technically impossible to do. Generally it is impossible.
21.09.2020, 22:00
Miroshnichenko Maxim Alexandrovich
OneBox CEO admin wrote:
The base currency of the system can be changed (set) only when OneBox is new (clean). In an existing system that has at least some data (goods, warehouse, finance), this is technically impossible to do. Generally it is impossible.
the client already has some data, but he can delete everything, in which case it is possible to change the currency?
24.09.2020, 13:47
yes, only "developers" will have to delete it under 0.
In fact, everything needs to be mowed down, except for goods (product) and contacts (user).
If you need to mow - let the client create a topic on the forum on his own behalf, so that later there will be no complaints "I did not say to do this."
24.09.2020, 15:01
