Please tell me, for the convenience of working with categories - it would be nice if the entire table was editable directly from the interface, now it only works for checkboxes.
[file]14053[/file]
Is it possible to make the table possible to edit the table without going to the settings of each category, but simply from the general table?
And it would also be convenient, as in all other lists / tables - to add import / export categories. Any lists of work with entities should have this possibility of editing. [file]14054[/file]
Is it possible to make the table possible to edit the table without going to the settings of each category, but simply from the general table? And it would also be convenient, as in all other lists / tables - to add import / export categories. Any lists of work with entities should have this possibility of editing.
Ustimenko Igor OneBox production OneBox CTO wrote: the data in these tables does not change often enough to make edits there
Even the first time it takes a lot of time to complete, not to mention editing. Why don't you make a single style and functionality in similar lists?
Ustimenko Igor
OneBox production
I don't see the value of spending time and money on this.
Kornev Mikhail
Ergo wrote:
Ustimenko Igor
OneBox production
