How can I copy an addendum field to a payment in an addendum field to a process?
win automation when adding a savings payment: https://take.ms/HIkOP
22.01.2022, 16:43
Куприян Владислав Валерьевич
Yarina
Having revised, not working
Having done the same for setting the same as for adding and for editing, also data from the payment description field are not copied in the process add-on field
How do you work, show me how
Vzagalі description dії yakiy ambiguous
Tobto i naming yak bi sound so mi z process zapovnyuєmo fields
Ale, the confusing checkbox "If the payment is tied to a process, replace variables for processes and letters in the value"
24.01.2022, 21:23
This action, obviously, only saves the field for the payment, and not for the process. I misread it on the OS, there are a few more changes and it’s not possible to enter the change, as you have on the screen.
the axis here is check for a box, maybe it will help you: https://1b.app/ru/forum/finances/12739-otsiniti-dorobku-dii-dlya-platezhiv/
25.01.2022, 12:14
