Stopped importing payments
https://farys.crm-onebox.com/
Hello. For 3-4 days, payments from Privat24 have ceased to be imported. Everything worked before. Recreated the merchant, nothing helps. What is the reason?
Perhaps because on 10/15/2021 your box changed its IP address.
18.10.2021, 15:36
IP changed, but nothing changed.
18.10.2021, 17:46
Maybe not on the one, the IP was changed,
The logs say that the IP is not suitable: invalid ip: 135.181.149.40
18.10.2021, 22:41
Well, this IP is. 135.181.149.40 - I check on the domain and this one pops up. Which one is correct then?
18.10.2021, 22:47
I don't know where you changed the IP. But the answer from the private is exactly that.
[2021-10-19 10:46:05]
[message] => invalid ip:135.181.149.40
Install the API app https://crm-onebox.com/en/app/app-api/
This application allows you to view system logs. In the log with the name privat-2021-MM-DD.log you can see the responses from the private.
19.10.2021, 10:48
I set the IP in the private merchant settings for individuals. I see it in the log, but that doesn't make it any easier. How to enter an IP address in Private?
19.10.2021, 22:33
To learn how to set up permissions in Privat, contact the Privat TP.
As far as I remember, in Private this is the Business -> Merchant setting and there you don’t need to specify anything other than IP and cards.
20.10.2021, 11:01
BEFORE this everything worked. Everything is set up correctly. I threw the screen. If the problem is in the IP, which one should be specified?
20.10.2021, 14:45
Server IP: 135.181.149.40
The answer is given by Privat.
There is no point in asking questions why Privat does not accept requests from the server with the given IP.
I repeat, with this question, contact the Privat TP.
When everything is set up correctly, everything works.
20.10.2021, 17:33
Private support said that everything is OK and working properly. If there is a problem, then only in the IP from which the request is made. What IP to indicate? https://2ip.ru says 135.181.149.40.
There is a problem and it needs to be solved somehow.
21.10.2021, 12:03
