Integration with monobank is configured. It pulls up data from 2 cards (black and white), but you need to pull it up only on a white card.
Mono support answered that the api has an accounts array and the type is passed there. For a white card, this is white [file]10406[/file]
https://api.monobank.ua/docs/
Is it possible to add the ability to specify from which type of card to pull up a payment to the "Monobank Statement" action setting?
Integration with monobank is configured. It pulls up data from 2 cards (black and white), but you need to pull it up only on a white card. Mono support answered that the api has an accounts array and the type is passed there. For a white card, this is white https://api.monobank.ua/docs/ Is it possible to add the ability to specify from which type of card to pull up a payment to the "Monobank Statement" action setting?
Monobank replied that it is possible to pull up payments only with a white card using this:
You already indicate it in action - indicate the desired card and apparently it should work)
