There is integration with https://crm-onebox.com/en/app/tinkoff/
Tell me where to get the keys to integrate with this service? Tech support replies that they do not issue such accesses. Is the integration relevant or improvements needed?
There is integration with https://crm-onebox.com/en/app/tinkoff/ Tell me where to get the keys to integrate with this service? Tech support replies that they do not issue such accesses. Is the integration relevant or improvements needed?
At the time of creating the integration, we were provided with a terminal ID and password, on the side of the bank account it was necessary to register the link [boxurl]/tinkoff/push/ Requests are sent to https://securepay.tinkoff.ru/v2/ Perhaps something has changed in 2 years, you need to find out from Tinkoff support.
To check the relevance of integration according to https://acdn.tinkoff.ru/static/documents/merchant_api_protocoI_eacq.pdf, you need access (terminal key and secret key)
They can be sent to d.zamogylnyi@crm-onebox.com
