The problem of homelessness
Previously, I posted hundreds of products via https://crm.smartid.com.ua/app/storage/process/incoming/
I simply added an existing item to the cart, and made a posting, it was uploaded to all platforms, and everything was fine in the store itself.
Lately, I've been creating products by copying similar products in a category, then posting them as before, but the products aren't being unloaded to the warehouse and after posting, the Quantity in stock is 0.
Although the posting operation is successful, it shows the quantity, price, etc.
Please check, for example, article numbers 1558, 1559, 1560, the last 3 added and posted products
Original question is available on version: ua Максим
https://crm.smartid.com.ua/app/product/21442/edit/
this product in the product list is lit as in stock. What exactly is wrong?
25.06.2025, 10:40
Горобець Максим
lace
1. If you go to products https://crm.smartid.com.ua/app/product/?searchfulltext=1558 quantity in stock 0
2. The flow is not transferred to sites operating on the API with OV
25.06.2025, 11:32
Максим Original comment available on version: ua
Горобець Максим
in the product itself, if you go to the product page - the quantity in stock is also 0
25.06.2025, 11:33
quantity in stock 0
I showed you on the chest that there is 9 in the warehouse field.
let's go with screens where you are watching.
25.06.2025, 11:37
Горобець Максим
lace
quantity in stock 0
I showed you on the screen that there is 9 in the warehouse field.
25.06.2025, 11:41
If you are talking about the "Quantity in stock pt" field, then this is an additional field and you yourself must do something with it - the system should not write anything in it by default. Remember what you configured where to fill it in
25.06.2025, 12:19
Горобець Максим
lace
If you are talking about the "Quantity in stock of PT" field, then this is an additional field and you yourself must do something with it - the system should not write anything to it by default. Remember where you configured it to fill it in
Before restoring from backup, this quantity was filled automatically, and the stock was transferred to the factory. Immediately after the restoration, these problems with the stock of goods began.
25.06.2025, 14:38
Well, make it so that it can be filled in, what's the problem?
25.06.2025, 15:06
Горобець Максим
lace
Well, make it fill in, what's the problem?
in that we don't know how, otherwise we wouldn't have created the topic)
25.06.2025, 17:18
Горобець Максим
lace
If there is a way to link the stock that will be transferred to all warehouses and the production line via a standard field, we would be grateful if you could tell us how to do it.
25.06.2025, 17:32
lace
check with the integrator how he did it, I also don't know how it was configured.
26.06.2025, 10:41
Горобець Максим
lace
lace
Topics are not created here when there is an opportunity to do it yourself or someone knows how to do it themselves. Similarly, if there was an opportunity to contact the integrator - we would not create a topic either. We created it because there are no other options
26.06.2025, 17:14
Горобець Максим
lace
Do you have the opportunity to check? Because you have to manually change the drain at all sites
25.07.2025, 10:20
