Good afternoon. Action once per hour "Create a process based on actual payments" or "Create a process if a payment was made in a certain business process" if payments are immediately linked to processes. Also in the process there are procedures when adding a payment, in which you can put a notification action you can also put the apk https://1b.app/ru/app/newcommunicationscenter/, then by clicking on your avatar on the top right there will be a notification setting. There you need to enable the necessary and be sure to save. If the payment goes to the account where you are responsible, a notification will be sent to the communication center.
Hourly action "Create process based on actual payments" or "Create process if a payment is made in a specific business process" if payments are immediately attached to processes. Also in the process there are procedures when adding a payment, in which you can set the effect of the message
you can also install the app https://1b.app/ua/app/newcommunicationscenter/, then after clicking on your avatar on the top right, you will have the message settings. There you need to include the necessary ones and be sure to save them. If the payment goes to an account where you are responsible, there will be a message in the communications center.
I did the action once an hour, created a process, there is a procedure that there should be a payment notification, but the messages never come, I'm doing something wrong
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
Department of Care
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
OneBox production wrote:
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
[file]21186[/file]
[file]21187[/file]
[file]21188[/file]
[file]21189[/file]
[file]21190[/file]
that's all, now you need to create a payment to receive notifications. Today, there are no payments from these processes
There was a payment, but nothing happened (
[file]21191[/file]
Department of Care
[file]21191[/file]
[file]21191[/file]
[file]21191[/file]
[file]21191[/file]
[file]21191[/file]
[file]21191[/file]
